2004 Pontiac Vibe Oxygen Sensor and Oil Build Up
2004 PONTIAC VIBE
54,000 MILES • 4 CYL • FWD • AUTOMATIC
GSTOTZ
The last time I had my oil changed, they left the oil cap off and about 3 quarts of oil were splashed all over under the hood. I had it degreased but the following day my check engine light came on indicating a failed oxygen sensor. Is this most likely the result of the oil build-up and should I insist that the oil change business cover the costs?
Jan 27, 2009 at 2:41 AM
MMPRINCE4000
  • 8,548 POSTS
It is most likely caused by them using a power washer ot water on the engine, causing a weak connection to the electrical connection to O2 sensor.
They caused the problem, have them fix it on their dime.
They could have caused the engine to sieze due to lack of oil.
Mar 21, 2009 at 1:31 AM
