1997 Pontiac Transport Rough Idle Hiss
LJYAROS
I have a 97 Pontiac Transport with 138,000 miles. I noticed today when under the hood while it was running that the engine sounds like it's leaking air like a flat tire. It has also been idling rough the past few days. Any idea what it could be?
Jul 20, 2006 at 3:00 PM
MIKEYBDMAN
  • 623 POSTS
Rough idle plus hissing noise usaly mean vacuum leak. I would look at all of the vacuum hoses atteched to the throttle body and follow them to their respected valves. Dont forget to look at the one that leads to the transmission.
Jul 21, 2006 at 8:17 AM
Suggested Repair
Inspect all vacuum hoses at the throttle body and follow them to their valves, including the hose to the transmission, for a vacuum leak causing the hissing noise and rough idle.
Conversation Summary
The owner of a 1997 Pontiac Transport with 138,000 miles reports a hissing sound like leaking air while the engine is running, along with a rough idle for several days. The expert says this usually indicates a vacuum leak and recommends checking all vacuum hoses attached to the throttle body, tracing them to their valves, and including the hose that leads to the transmission.
