1997 Pontiac Transport Idle Noise
SGUERECA
I have a 1997 Transport that had an engine rebuilt, original miles on engine were 80,000. My engine had gone out so now that I have a rebuilt one it's making a strange noise as if it were about to die out.
It feels as if it is not getting enough gas when it's idle. When I accelerate it does not make that noise and it runs fine. We have tried replacing the Mass Air Flow sensor since that's what the scanner had picked up but it did not help.
Do you have any ideas (everything from spark plugs, wires, water pump, belts, tensioners were replaced)
Thank you
Oct 14, 2007 at 1:56 AM
MERLIN2021
  • 17,250 POSTS
Check for air leaks in the air induction plenum. And vacuum leaks...get a can of spay gumout, spray the vacuum hoses and the intake manifold, if the idle changes, you have found the leak...
Oct 14, 2007 at 1:59 AM
Suggested Repair
Check the air induction plenum and vacuum hoses for air leaks. Spray Gumout around the vacuum hoses and intake manifold; if idle changes, the leak is located.
Conversation Summary
The owner of a 1997 Pontiac Transport with a rebuilt engine reports a strange idle noise as if the engine is about to die and feels fuel-starved at idle, though it runs fine when accelerating. The MAF sensor, spark plugs, wires, water pump, belts, and tensioners were already replaced without fixing it. The expert recommends checking the intake plenum and vacuum hoses for leaks by spraying Gumout and noting any idle change.
