1998 Pontiac Transport separating crankshaft pulley
1998 PONTIAC TRANSPORT
250,000 MILES • 6 CYL • 2WD • AUTOMATIC
SPARIS
the crankshaft pulley has moved out of it's proper position. in other words, it is working it's way away from the engine. this has caused the serpentine belt to not sit properly on the pulley and this is damaging it. What has caused the pulley to move outward from it's proper position and what can i do to repair it. thanks.
Jan 1, 2010 at 12:12 PM
MERLIN2021
  • 17,250 POSTS
Depends on if for some reason(Very Rare) the bolt loosened, or as is usually the case, the rubber damper section is worn out, that require the replacement of the harmonic balance(Crank Pulley Assembly).
Jan 1, 2010 at 12:18 PM
