1998 Pontiac Transport overheating issues
1998 PONTIAC TRANSPORT
BURDI77
I have a 98 Transport, 150,000 + miles, 3.4 eng. The problem is intermiittent. I can get in it cold, drive it 2 blocks and the gauge reads in the red and the light comes on and at other times I can drive it for miles and it's fine. I can smell coolant everytime I run the car but it's not losing any. The car is running very rough and the service engine light keeping coming on and off. Sometimes the coolant in the overflow is steaming and sometimes it is lukewarm. I have flushed the radiator and made sure that there is no air in it, replaced the thermostat and the heat control sensor. There is no white smoke in the exhaust and no white paste at the oil fill spout. The oil is clean and doesn't show any sign of coolant in it. The water pump is not leaking or making noise. Last winter the heater stopped blowing warm air but the other problems did not show up until recently. We did have a mechanic change the three back spark plugs on the firewall side, don't know if it could be connected, but never had the overheating issue until shortly after this was done. Just thought maybe there could be something back there that could have gotten knocked loose. Long shot I know but I am stumped at this point.
Oct 1, 2007 at 4:20 AM
SERVICE WRITER
  • 9,123 POSTS
The 3.4 are common for intake manifold gasket problems that possess various symptoms. Look at the areas around the manifold for coolant seapage that may be burning off onto the exhaust manifold. Also look for signs of rust/pitting on the waterpump pulley. Sometimes a tell tale water pump problem will show a line of the hood from the blet slinging coolant on it. Waterpumps can be an intermittant kind of thing.
Oct 1, 2007 at 4:25 AM
BURDI77
Thanks for the info, it gave me some things to check. I did see the line of rust on the inside of the hood and will check the water pump. I got a diagnostic reader and it said there was an issue with the number two cylinder. I pulled the plug and it is burned and black, I just put these in recently. The other two in the front were fine. The reader only showed the one code.
Oct 6, 2007 at 10:07 AM
SERVICE WRITER
  • 9,123 POSTS
black is a sign of rich burning. Lack of spark perhaps, too much fuel... Try swapping the plugs and wires to different cylinders. Swap the left and center plugs and the right and center wires and see if the miss changes.
Oct 8, 2007 at 11:42 AM
