1998 Pontiac Transport Over heating
20,000 MILES • 6 CYL • FWD • AUTOMATIC
LUJONES
I have a 1998 Pontiac Transport that after driving it several miles the temp gauge goes into the red. Sometimes it just nearly goes into the red then back down to normal. I have replaced the termostat, water pump & radiator. I have removed all air from the system, performed a pressure test to see if I was losing pressure and no pressure is being lost. No service engine lights to be reported. Any suggestions?
Jul 1, 2010 at 12:07 AM
RICHZOMBIE
  • 173 POSTS
You may want to have a local radiator shop check it out and let them know what all you have replaced. It kind of sounds like air in the coolant system.
Jul 1, 2010 at 1:12 AM
EWH5053
[quote:6277c6321f="lujones"]Engine Performance problem
1998 Pontiac Transport 6 cyl Front Wheel Drive Automatic 200,00 miles
I have a 1998 Pontiac Transport that after driving it several miles the temp gauge goes into the red. Sometimes it just nearly goes into the red then back down to normal. I have replaced the termostat, water pump & radiator. I have removed all air from the system, performed a pressure test to see if I was losing pressure and no pressure is being lost. No service engine lights to be reported. Any suggestions?[/quote:6277c6321f]
I am having the same problem, I have tried everything you did and it still is overheating!
have you fixed yours yet?
Nov 9, 2010 at 12:23 PM
