Hi X971-
You have to find where the coolant is disappearing to. It's either an external(outside the engine) or internal(inside the engine)leak. Check under the car after you've refilled it. Also check the carpet under the dash to see if it's wet.
If no problem there then the leak is internal and would need to be further diagnosed.
Hope that helps
SPONSORED LINKS
Tuesday, January 9th, 2007 AT 9:04 PM
