2004 Pontiac Sunfire headlights
78,000 MILES • 4 CYL • FWD • AUTOMATIC
CORHERYR
My right hand high beam and low beam do not work properly. The left side works great and I have changed the right bulbs to the left sockets and the bulbs are ok. Also I found out my radio doesn't work and the clock numbers are hard to read. The right highbeam as well as the low beam do liite up but very very dim. I hope you can help me.
Thanking you in advance
Cor Herweyer
P.S how is the donation transfered from mew to you?
May 3, 2010 at 6:45 AM
CARADIODOC
  • 34,416 POSTS
Hi corheryr. Welcome to the forum. Unplug the left bulb. If the right one goes from dim to out completely, there is a bad ground either in the socket or where the wire is bolted to the body. One word of warning. GM does some really weird stuff with the wiring for their daytime running lights. There could be more involved than just a simple ground wire.
caradiodoc
May 3, 2010 at 7:35 AM
