1999 Pontiac Sunfire headlights won't work
137,000 MILES • 4 CYL • 2WD • AUTOMATIC
TALON6713
I have a 1999 Pontiac Sunfire 2.2 liter (SE). The other night my headlights would not come on, the daytime running lights work though. Nither the high beams or low beams will not work although.I checked all the fuses in my dash and the conections to the headlights themselfs. The headlights came on going to work today, but would not turn on coming home though. I was thinking it maybe a headlight relay problem. I just dont know where that is in my car. I was wondering if you could point me in the right direction.
Oct 5, 2010 at 7:37 AM
JDL
  • 16,098 POSTS
The voltage to the headlamps is hot all the time, when the drl isn't energized. Actually, there is voltage to the lamps even then, but wired a little different, the drl relay is ground for the lamps when energized. When not energized, the dark blue wire is headlamp voltage for one side. orange wire for the other. On and off, bright and dim, is controled on the ground circuit through the multifunction switch. DRL is a little different.
https://images.2carpros.com/forum/automotive_pictures/170934_sunfire_headlamps_1.jpg
Oct 5, 2010 at 8:32 AM
TALON6713
thank you for the quick response back to my question although I'm not familair with wiriing diagiams. I was hoping someone could provide where the headlight relay is?
Oct 5, 2010 at 9:06 AM
JDL
  • 16,098 POSTS
The DRL relay is behind lower left side of dash.
Oct 5, 2010 at 9:25 AM
TALON6713
Thank you very much!!
Oct 5, 2010 at 9:33 AM
CAMAROSCOTTY
So was the relay the issue?
Jan 1, 2011 at 7:21 PM
JDL
  • 16,098 POSTS
Are you still having issues?
Mar 1, 2011 at 2:27 PM
TALON6713
The DRL relay was the problem,and it was fixed
Mar 1, 2011 at 3:07 PM
JDL
  • 16,098 POSTS
Good job.
Mar 3, 2011 at 11:07 AM
ASHLEYADAM
  • 6 POSTS
My 1996 Sunfire DRL are not working at all but Hi/Low beams are fine. I'm thinking I need to replace DRL relay. Can you attach photo of relay/location?
Mar 23, 2012 at 9:31 PM
JDL
  • 16,098 POSTS
My info says the relay is located on the front impact bar, sorry, I don't have a picture.
Mar 24, 2012 at 9:24 AM
