2001 Pontiac Sunfire Bulb Replacement
2001 PONTIAC SUNFIRE
100,881 MILES • 4 CYL • 2WD • AUTOMATIC
MARYFRAN
Could you tell me how to replace the rear (left) directional signal?? Thank-you
Mar 17, 2008 at 11:22 PM
RHALL77
  • 3,361 POSTS
remove the wing nut securing the trunk liner. This will access the rear lights. Twist the socket and remove the bulb. you might wanna check, some of those sockets went bad and had to be replaced.
Mar 18, 2008 at 12:10 AM
