1997 Pontiac Sunfire shakes
1997 PONTIAC SUNFIRE
136,000 MILES • 4 CYL • FWD • MANUAL
FIREFIGHTER241154
  • 8 POSTS
What would cause this car to shake and shimmy at speeds above 70 miles per hour?
What causes the air bag light to stay on ?
Apr 24, 2008 at 8:16 PM
LEGITIMATE007
  • 5,121 POSTS
that shake and shimmy might be causing the air bag light to stay on/ do you drive with the wheel tilted up?
the wobble is from a bad front end allighnment or bad tie rod ends. you should be able to correct that problem with a front end alingnment
Apr 24, 2008 at 8:32 PM
