1997 Pontiac Sunfire ABS light
1997 PONTIAC SUNFIRE
89,000 MILES • 4 CYL • 2WD • MANUAL
1TAILTASTER
My son and I changed the rear brakes on his car and everything is fine. But now the ABS light on the dash stays on. Is there a problem and is there a correction that can be made?
Oct 15, 2009 at 8:25 AM
SERVICE WRITER
  • 9,123 POSTS
There will be codes set in the computer for the abs, just like a CEL. Once you have the code(s) we can go further.
If any connectors for the abs system were unplugged or harnesses damaged while changing the brakes, this can set a code and lite the light.
Oct 15, 2009 at 9:49 AM
