Electrical problem
1997 Pontiac Sunfire 4 cyl Manual 212000 miles
Even without the ignition key in the ignition the starter motor continues to turn over?
Tuesday, September 7th, 2010 AT 6:10 PM
JDL
MECHANIC
The purple wire at the starter solenoid S terminal, should not be hot with key off. If it is hot, either a problem with ignition switch or circuit shorted to voltage. If that wire isn't hot and the starter still cranks, look at the starter solenoid.
