Are you using a different key? Try a Passlock relearn procedure:
Perform security system relearn.
1. Let car sit for more than 10 min. W/ key off.
2. Attempt to start engine; leave key in the run position (monitoring the theft light).
3. After 10 min. The light will change state.
4. Turn key off and wait 10 sec.
5. Attempt to start; if stalls, wait another 10 min. W/ key on.
6. Turn key off for 10 sec.
7. Attempt to start; repeat step 5 - 6 if necessary.
8. The security system will relearn on the 4th starting attempt and the engine should start and run.
SPONSORED LINKS
Wednesday, March 24th, 2010 AT 3:04 PM
