1997 Pontiac Sunfire
BRENDA CROWE
  • 1997 PONTIAC SUNFIRE
Noises problem
1997 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
my car made a strange noise and then you smelled something hot like rubber burning and then I turned it off and then it wouldn't start back up again
Tuesday, September 21st, 2010 AT 10:38 PM
What is it doing? -Cranking over and will not start or just won't crank at all/nothing when you turn key to start position
Wednesday, September 22nd, 2010 AT 6:59 AM
BRENDA CROWE
  • 5 POSTS
It does nothing. At all
Wednesday, September 22nd, 2010 AT 1:16 PM
No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link, the starter, starter relay, park and neutral switch and ignition switch assuming the battery and connections are good.
Wednesday, September 22nd, 2010 AT 3:40 PM
BRENDA CROWE
  • 5 POSTS
Thanks so much for you advice. It was the starter after all.
Thursday, September 23rd, 2010 AT 1:19 PM
