Check for 12 volts at the small wire(purple) on the starter with key in crank position. If none go to Neutral safety switch on top of trans where shift cable hooks up and test same wire there if none check the yellow wire, if has power the switch is bad ( transaxle range switch) neutral safety switch. If no power at yellow wire, go under the column and check the same yellow wire, if no power there in crank the ignition switch is bad
SPONSORED LINKS
Tuesday, February 12th, 2008 AT 7:40 AM
