Car will run for about ten minutes then stall. It has to sit for a few minutes then will start and stall again in ten minutes
Wednesday, January 27th, 2010 AT 7:09 PM
JDL
MECHANIC
Welcome to the forum. How long since a tune-up? After it stalls, have a helper crank it while you check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Can you check for trouble codes, at the least, you need an obd11 code reader.
