1996 Pontiac Sunfire ignition control module
MARKGTZ2
1996 Pontiac Sunfire 4 cyl
where is the ignition control module located?
Nov 29, 2009 at 5:45 AM
JDL
  • 16,098 POSTS
Welcome to the forum, for the 2.2 litre engine, the ignition module is under the coil pack and looks like the picture.
https://images.2carpros.com/forum/automotive_pictures/170934_sunfire_ignition_module_1.jpg
Nov 29, 2009 at 7:05 AM
MARKGTZ2
where is the coil pack?
Nov 29, 2009 at 7:16 AM
MATTF87
If you get under the car, crawl back until you can see up through the motor a bit, just against the walls of the cab. You can actually follow the plug wires all the way to your coils. That is the Easiest way to find them.
Dec 1, 2009 at 2:07 PM
