1993 Pontiac Sunbird wont start
MINA1
  • 1993 PONTIAC SUNBIRD
Engine Mechanical problem
1993 Pontiac Sunbird 6 cyl Front Wheel Drive Automatic
i crank it up then it staled then nothing I know the battery is good because all the bells for the door and key in the ignition comes on. It doesn't turn over the starter doesn't turn there is no other sound.
Wednesday, September 8th, 2010 AT 8:19 AM
Load test the battery and double check the connections if okay could be one of the following starter motor, starter relay if it has one, transmission range switch and ignition switch.
Wednesday, September 8th, 2010 AT 8:42 AM
