1989 Pontiac Sunbird no start
DALESSEARCHING2008
  • 1989 PONTIAC SUNBIRD
  • 4 CYL
  • FWD
  • 95,000 MILES
Car will not start, engine turns over fine and plugs are ok still will not start
Thursday, April 30th, 2009 AT 8:38 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Thursday, April 30th, 2009 AT 9:13 PM
