1993 Pontiac Sunbird Stalls While Driving
PONTIAC
ALEEB
Hi Im new to the forum and have a question about the way my car is driving. I have a 1993 Pontiac Subird LE, with a 2.0L engine and approx. 105k miles on it.
Everytime my mother or I drive it, it stalls heavy. It' ok sometimes but gets worse the longer it's driven. It holds back like it does not want to drive. My mother and I replaced just about everything from spark plugs and cables, gas filter, air filter, oil change, etc. but it still acts the same. My mother recently told me that the reason it has been acting like that is because she just found out that my uncle put in one of the spark plugs wrong and now the engine has a gap in the hole where the plug was incorrectly put in.
do you think this could be the reason for my car to drive so poorly and if so is there anything that I could in order to correct the problem? thanks in advance for the help.
Apr 22, 2007 at 5:22 PM
SERVICE WRITER
  • 9,123 POSTS
"gap in the hole where the plug was incorrectly put in"
Can you elaborate on that?
Apr 22, 2007 at 11:03 PM
ALEEB
Yes. The plug was screwed in crooked so now it's hard to properly allign any spark plug that goes into the hole.
Apr 23, 2007 at 4:26 AM
SERVICE WRITER
  • 9,123 POSTS
That's a problem, may or may not be related to the stalling. regardless that should get taken care of. May need to pull the head, unless a heili coil can be put in.
Apr 23, 2007 at 11:36 AM
ALEEB
Do you know what could cause the stalling because I really want to get it taken care of. Thanks for the replies.
Apr 25, 2007 at 9:07 AM
SERVICE WRITER
  • 9,123 POSTS
No I don't. The stalling can e a multitude of possibilities, but regardless if there is a lack of compression from the plug not sealing, that will take priority in your journey.
Apr 25, 2007 at 2:09 PM
ALEEB
Ok, I thank you for all of your assistance.
Apr 26, 2007 at 3:08 AM
Suggested Repair
Repair the damaged spark plug threads first, using a Heli-Coil if possible or removing the cylinder head if the threads cannot be restored. A plug that does not seal can cause compression loss and should be corrected before chasing the stalling, which was not specifically diagnosed.
Conversation Summary
The owner of a 1993 Pontiac Sunbird LE with a 2.0L engine reported heavy stalling and holding back that worsened the longer the car was driven. Plugs, cables, filters, and oil had already been replaced. A spark plug had been installed crooked, damaging the threads so later plugs would not align or seal. The expert said the damaged hole should be repaired with a Heli-Coil if possible, or by removing the head, because lost compression takes priority. The expert did not identify a specific cause for the stalling.
