Pontiac Hard Left Steering
PONTIAC
98_GTP_SC
My Power Steering I Think Is Out on the left side.
I can turn i wheels to the right. but when i turn my wheels to the lef tits as is the power steering has gone out. Any solutions?
Jun 3, 2007 at 12:19 PM
SERVICE WRITER
  • 9,123 POSTS
You need to add some left power steering fluid.
Sorry.
I would be very concerned of a mechanical binding of sterring/suspension components. If you jack the front end up, see if it moves easier or you can move the wheels by hand. See if there is any play in the wheels. IF nothing is obvious, disconnect the outer tie rod ends and turn each front wheel (not spin them around) and see which side is binding or not.
Jun 3, 2007 at 12:32 PM
Suggested Repair
Check for mechanical binding in the steering and suspension. Raise the front end and see whether the wheels move more easily by hand and whether there is play. If nothing is obvious, disconnect the outer tie rod ends and turn each front wheel to identify which side is binding.
Conversation Summary
The owner of a Pontiac says the wheels turn right normally, but turning left feels as if the power steering has failed. The expert dismisses adding fluid and recommends checking for mechanical binding in the steering or suspension by raising the front end, checking wheel movement and play, then disconnecting the outer tie rod ends and turning each front wheel to find the binding side.
