Pontiac Power Steering Smell and CEL
PONTIAC
CHI_T0WN1
I overfilled power steering fluid, I smell the fluid after awhile when car is running, lift up the hood and see fluid box a bit wet and now getting check engine soon indicator on. Does that mean anything...
Mar 4, 2007 at 3:11 AM
CHEVY22
  • 1,375 POSTS
NO , THE POWER STEERING PUMP IS NOT COMPUTER CONTROLLED , YOU HAVE ANOTHER PROBLEM , AUTOZONE WILL READ THE CODES FOR FREE AND JOT THEM DOWN AND GET BACK TO US SO WE CAN PROPEKY DIAGNOSE THE PROBLEM
Mar 4, 2007 at 4:19 AM
Suggested Repair
Clean the wet power steering reservoir and avoid overfilling it. Have the check engine codes read for free at a parts store such as AutoZone and return with the codes, because the power steering pump is not computer controlled and the light indicates a separate problem.
Conversation Summary
The owner overfilled the power steering reservoir on a Pontiac, then noticed a fluid smell, a wet reservoir, and a check engine light. The expert said the pump is not computer controlled, so the light is a different issue, and recommended a free code scan so the problem can be diagnosed.
