1999 Grand Am Power Steering Groan
1999 ALL OTHER MAKES ALL OTHER MODELS
GREGOOR78
I have a 1999 GRand Am that groans whenever I turn the wheel. The power steering fluid isn't llow but it's very frothy, sort of like a head on a beer. Any ideas as to what would cause that??
Jan 30, 2006 at 11:39 AM
CHEVY350GUY
  • 109 POSTS
there is air in your power steering system which is why your fluid looks that way. has there been any repairs done to your power steering. rack, lines, pump? if not your pump sounds like it could be allowing air in to the system through a possible bad seal. but start with the pump.
Feb 2, 2006 at 3:39 AM
GREGOOR78
So far no repairs to any of those. Thanks for the tip, I'll start there.
Feb 2, 2006 at 10:43 PM
Suggested Repair
Air in the power steering system is causing the frothy fluid and groaning when turning. With no prior repairs to the rack, lines, or pump, start by inspecting the power steering pump for a failing seal that may be drawing air into the system.
Conversation Summary
The owner of a 1999 Grand Am reported groaning when turning the wheel and frothy power steering fluid that was not low. The expert said air is entering the system and, absent prior power steering repairs, recommended starting with the pump as a possible bad seal. The owner confirmed no prior repairs and planned to check the pump.
