p0172
PONTIAC
WJ2893
1996 Pont.Grandprix,3.1,100000miles.p0172 system to rich bank 1. I am unable to get rid of this code.I have done a complete tune up,plus these new parts and sensors converter,o2sensors,mass air flow,map,throttlepos.idle air control,egr,gas cap.Also fuel press. is good. The car runs great but will not pass inspection if I just keep erasing the code.What else could this be?
Mar 15, 2007 at 11:17 AM
2CARPRO JACK
  • 11,533 POSTS
Tune up with OEM parts?
Mar 16, 2007 at 12:56 AM
PEPPERMRJ
  • 1,158 POSTS
Does it smell like it is running rich?
Are you using a K&N air filter? An oiled filter can play hell with a MAF even when it is new.
Did you replace both the upstream O2 and the one after the cat? Any exhaust leaks?
Check for vacuum leaks @ the hoses and Map.
What fuel pressure did you get with the engine off? Does the pressure bleed down?
Does the pressure fluctuate with the engine running?
I'd bet on a fluctuating pressure regulator or a leaking injector. Try some injector cleaner or have them professionally cleaned. I like chevron with techron.
Good luck and let us know. :)
Mar 16, 2007 at 3:51 AM
PEPPERMRJ
  • 1,158 POSTS
To: peppermrj
Posted: Sun Mar 18, 2007 2:08 pm
Subject: p0172
"Thanks for the input regarding my problem on this code.I found that there was a pinched return fuel line and the problem is now fixed. thank you again,Bill "
Thanxs for the update. :)
Mar 18, 2007 at 10:20 AM
