2001 Pontiac Montana AC Blows Hot
SWEET_MAMA
  • 5 POSTS
I have a 2001 Pontiac Montana 3.4L. The air is not working. It is full of freon with no leaks. The engine does not seem to "bog" down when the air is turned on. I have not gotten under the hood myself to be able to give a better description but if you tell me what I should look for/at I will let you know. It does blow, but no cool air.
Aug 31, 2007 at 4:21 AM
2CARPRO JACK
  • 11,533 POSTS
Have gauges actually been put on the system to verify pressure? Test light- check for power at the cycling switch (on the receiver/dryer) should have power on both sides if system is fully charged.
Sep 1, 2007 at 1:32 AM
CHANLEY28
If your van has rear A/C there is a line that goes from the front A/C system to the back underneath the driver side seat (under the van) It looks like a high pressure hose connecting to an aluminum line going to the back of the van. This line has caused many problems for all of the GM minivans, and the average price I have been given to replace this line (account leakage) is areound $600. Sorry to be the bearer of bad news, but this seems to be a VERY common problem with these vans.
Nov 24, 2008 at 12:49 PM
Suggested Repair
Verify actual system pressures with gauges. If the system is fully charged, use a test light to confirm power on both sides of the cycling switch on the receiver/dryer.
Conversation Summary
The owner of a 2001 Pontiac Montana 3.4L reports that the A/C blows air but not cold, the system is said to be full of refrigerant with no leaks, and the engine does not load when A/C is turned on. The expert advises confirming pressures with gauges and checking for power on both sides of the cycling switch at the receiver/dryer. Another participant notes a common rear A/C line leak under the driver's side on GM minivans, but that was not confirmed for this vehicle.
