2002 Pontiac Montana COMPRESSOR
79,000 MILES • 6 CYL • FWD • AUTOMATIC
DWALT
vehicle jumps up & down in the back of the van. air compressor runs continuously. got underneath and noticed hose was hanging from compressor. believe it is broken. where does this hose attach to and can you give me a picture of how to replace it and what size hose do I ask for?
Thank-you
Dec 26, 2008 at 9:42 AM
DOITYOURESELF
  • 48 POSTS
the hose goes from the compressor to the rear shocks, it should have quick release fittings, when you push the hose into the fitting it should tighten as you try to pull it back out. there is a wire clip or a plastic bushing to push on to release. some autoparts stores may have the replacement line its probably 1/8 inch airline, they should have a airshock line kit, I would replace it all new again.
Jan 17, 2009 at 6:46 PM
