2002 Pontiac Montana water leaking into front floorboard wh
2002 PONTIAC MONTANA
126,000 MILES • 6 CYL • FWD • AUTOMATIC
MELODYG
i have recently had this problem where whenever i use my a/c the front drivers side floorboard gets all wet. my dad has tried to find the problem, but not used to newer vehicles. can you help? i just need to know where the water could be coming from.
Aug 10, 2010 at 1:46 PM
GMTECH
  • 537 POSTS
If you are getting water in when your a/c is on, you are going to want to clear the drain from the evap core. I don't think you can get at it from the top, from underneath. there is a whole in the firewall, actually a spout on the passenger side that can get plugged.
Oct 26, 2010 at 2:23 PM
