1967 Pontiac LeMans Carb Float Sticks
Wish I had it on my bench--I could fix it blindfolded.
Wish I had it on my bench--I could fix it blindfolded.[/quote:212b37395a]
[quote:212b37395a="lemans"]
Thanks for the help, funny thing about it, it only happens if the car sits for about 5 days or more. I don't really trust the plastic one so I am going to get a brass one and give that a shot. - Thanks[/quote:212b37395a]
Suggested Repair
Check the plastic block over the float chamber for binding. On a metal float, look for shiny rub marks. Confirm the needle has the small clip that holds it to the float. If the needle sticks in the plastic cover, slightly enlarge the hole so the pin moves freely, and verify the top rubber washer and rod seal the vent.
Conversation Summary
A 1967 Pontiac LeMans with a 326 and Rochester 2GC floods because the carb float sticks, even after three rebuilds and a new float. Tapping the fuel filter temporarily frees it, and the problem mainly appears after the car sits about five days. Advice was to check a binding plastic float-chamber block, float rub marks, and a missing needle clip. Another owner fixed a sticking needle by slightly opening the plastic cover hole so the pin moved freely and confirming the vent seal.
