2002 Pontiac Grand Prix Key Stuck
CRH
2002 Pontiac Grand Prix 59,000 miles. Car starts fine but when turning car off, key won't turn back all the way and I can't get the key out of ignition. Help!
Feb 19, 2007 at 5:30 PM
2CARPRO JACK
  • 11,533 POSTS
That could be either the tumbler broken or the rack assembly in the column.No matter what its gonna have to come apart to find out what happened
Feb 20, 2007 at 6:27 AM
CRH
[quote:c18a837917="2CarPro Jack"]That could be either the tumbler broken or the rack assembly in the column.No matter what its gonna have to come apart to find out what happened[/quote:c18a837917]
I should say that at some point, the key does come out, but sometimes after 20-30 minutes of trying.
Is this something that an average locksmith could fix or is it a bigger problem? Any idea on how much $$ it could potentially cost to fix? Thanks :)
Feb 20, 2007 at 7:07 AM
2CARPRO JACK
  • 11,533 POSTS
Price depends on what is wrong in the column
Feb 20, 2007 at 7:28 AM
MCFERRANCE
  • 100 POSTS
I have a similar problem in a 2000 Grand Prix. At times (not everytime) when I use the trans. lock override near the shifter, I hear a clicking behind the dash just above the steering column. After I hear this, the key will turn back to the lock position.
Does anyone have any insight into the correlation of the clicking sound and the key turning back correctly?
Mar 26, 2007 at 4:26 AM
2CARPRO JACK
  • 11,533 POSTS
Might be the shift lock out solenoid sticking or other problem with the lock out system
Mar 26, 2007 at 5:41 AM
MCFERRANCE
  • 100 POSTS
I corrected my similar problem by replacing the electrical switch which controls the lockout solenoid.
See my post for 2000 Grand Prix DRL and Heater control.
Mar 30, 2007 at 7:19 AM
Suggested Repair
The steering column needs to be disassembled to determine whether the ignition tumbler or the column rack assembly is faulty. Also check the shift lockout system, including a sticking lockout solenoid and the electrical switch that controls it, since a similar Grand Prix was fixed by replacing that switch. Repair cost depends on which part is actually at fault.
Conversation Summary
A 2002 Pontiac Grand Prix starts normally, but the key often will not return fully to lock or come out, sometimes only after 20–30 minutes. The expert said the column must be taken apart to check for a broken ignition tumbler or rack assembly, and that cost depends on the fault. On a similar 2000 Grand Prix, using the transmission lock override produced a click above the column and then allowed the key to lock; the expert suspected a sticking shift lockout solenoid or related lockout problem. That owner reported fixing it by replacing the electrical switch controlling the lockout solenoid.
