1998 Pontiac Grand Prix Key Stuck
TINKLEBEAR
Our son had to leave his 1998 Grand Prix V6 140 thousand miles at his aunts house we went and picked it up for him. We found out that the key will not come out of the ignition Is there a way to get the key out with out removing the ignition switch? As it is now we only have that on key leaving us no way to lock up the car or keep others from taking it We are not familiar with this model if it has a lock button or some sort we were not able to find it
Apr 26, 2007 at 11:20 AM
LSUSSEL
  • 252 POSTS
these cars like all cars have a locking mechinaism that will not let you remove the key unless its fully in park.
make sure the car is compeltely in park.
Apr 28, 2007 at 4:18 AM
KEITH.55
  • 7 POSTS
I have found an interesting way to get by this. Under my steering column there is a 1 1/2 X 3/4" popout panel that conceals a manual override for the steering lock! I know it doesn't address the problem but it sure is easy to use. I just put my finger into the hole and depress the pin and AMAZING ... the key returns to off and comes out every time. If your year has this, it may work for you. keith.55
May 1, 2007 at 4:10 PM
AQUABOGGIE
I own a Pontiac Grand Prix 1999. I am experiencing a problem with getting my key out of the ignition. Now, I already found the pin under the steering wheel mentioned in another post on this sight that allows you to remove your key from the ignition. Sadly, I have used it so much that it has broken. I know that in this case there is a battery that needs to be changed. Do you know where to find this battery????
May 4, 2007 at 7:50 PM
MCFERRANCE
  • 100 POSTS
I had the same problem a few months ago and listed it under a 2000 GP. When I changed the actual electrical ignition switch, cost of $100 for the part, all of the problems went away. If you are not able to "override" it anymore by pushing the plunger from under the column, then you may also need to change it which it is called the lock actuator which is most likely a dealer item.
May 7, 2007 at 7:21 AM
Suggested Repair
Confirm the shifter is fully in Park so the ignition interlock can release the key. If it still will not come out, a small access panel under the steering column may hide a manual override pin. If that override no longer works, owners reported replacing the electrical ignition switch or the lock actuator.
Conversation Summary
The owner of a 1998 Pontiac Grand Prix could not remove the only key from the ignition and could not lock the car. The expert said the interlock will not release the key unless the transmission is fully in Park. Other owners described a steering-column override pin, and said replacing the electrical ignition switch or lock actuator resolved a similar problem after the override failed.
