cooling fan not working
MARKK
1995 pont grand prix 144k 3.1L I chevked the fuses relays and fan motor. all are OK. I couldn't find the temp. sensor location or a photo of it in my manual. will you give me this info? or any other advice to diagnose.
I also have a low oil level light come on from time to time and the oil level is OK. I can't find that sensor in my book either.
Thanks, Mark
Feb 7, 2007 at 4:05 AM
GARFIELD
  • 197 POSTS
the temp sensor is normally located close to the thermostat housing. As for the oil level sensor, start by looking around the just above where the oil pan bolts to the block for a electrical connector that penetrates the engine block.
Feb 7, 2007 at 11:53 PM
