There are many things that will leak and cause the low coolant light to come on,
1. Lower intake gasket leak
2. Upper intake helmet cracked or warped leaking coolant
3 water pump
you say the shop stated there was coolant in the oil? If so and you didnt overheat it its probably an intake gasket or the upper intake which is plastic, whatver you do dont drive it with the oil intermixed, it will surely ruin the lower end
SPONSORED LINKS
Thursday, February 22nd, 2007 AT 12:13 PM
