My temp gauge starts from cold and when I hit running temp and thermostat opens temp gauge gos just under hot redline when car is not overheating. I replaced radiator cap, coolant flush, thermostat, radiator hoses, coolant temp sensor and bled cooling system. Ive even ran car for over an hour today at idle in 90+ weather with my digital temp gun and it stayed at 217 the entire hour even though temp gauge said I was overheating 5 minutes after starting. My gauge has been doing this for almost a year now and once at running temperature says I'm overheating but the car has never ran hot as I check it religiously with my digital temp gun. So once again when I start the car its at cold and after letting it run for 5 minutes or so to get to running temperature after the thermostat opens up temperature gauge goes to hot even though car is at normal temperature. Any ideas?
SPONSORED LINKS
Monday, August 31st, 2015 AT 6:49 PM
