Either a bad waterpump of a restriction in cooling system.
If cooling system has never been flushed, I would drain and flush cooling system and replace thermostat.
If problem persists, replace waterpump. Some cars are equipped with waterpumps that have a plastic impeller, these can seperate from shaft and reduce coolant flow at slow speeds.
SPONSORED LINKS
Wednesday, January 6th, 2010 AT 6:32 AM
