2002 Pontiac Grand Prix Oil leak and shifting hard
ALCALYPSE
  • 2002 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 146,000 MILES
My first problem is the most severe. It started out leaking a little bit of oil, then within 2 weeks, it was a deluge. When you put the oil in, it comes right back out from about the midpoint of the engine. I checked the oil pan and the problem is not there. I am wondering what it could be, a gasket or something easy, or more severe like a cracked piston head. It looks clear, not foamy, so I am pretty sure it is not mixing with any antifreeze. On to my second problem. When the car has been driving for a while and the engine warms up, the transmission starts to shift really hard, sometimes physically jolting the car in the first 2-3 gears. Sometimes when you turn the engine off for a minute, the problem stops, other time it does not. Thank you for oyur help!
Saturday, March 13th, 2010 AT 10:22 PM
MMPRINCE4000
  • 8,548 POSTS
If you are talking about engine oil in question 1, then there has to be a major gasket leak or hole in oil pan.
Get problem 1 fixed first, if is losing oil that fast you will sieze the engine.
Sunday, March 14th, 2010 AT 8:34 AM
