Make sure the oil pan bolt is tight and not cross-threaded and the filter is not loose or over tightened.
Sometimes when you remove the oil filter, the rubber seal will stay on the oil filter housing, when you put the new filter on this is a leak for sure.
SPONSORED LINKS
Monday, March 31st, 2008 AT 6:28 AM
