2000 Pontiac Grand Prix Oil Leak
FACELIET
  • 2000 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 20,000 MILES
Hope to find the PROBLEM
Tuesday, May 26th, 2009 AT 4:51 PM
SERVICE WRITER
  • 9,123 POSTS
Use mirrors and good lighting when trying to find oil leaks. There are chemical additives that will dye the oil to help find a leak. Best way is to clean off all the old built up oil or anything else that is able to camo the leak.
It may leak hot and it may leak when cold. May need to run it and watch. Make sure the pcv system is sucking vapors out of the crankcase.
Tuesday, May 26th, 2009 AT 7:24 PM
