Remove valve cover gaskets and inspect them for tears/rips.
While possible the intake is leaking, I would think you would have leaking coolant also.
If all else fails, clean engine and put dye into oil, inspect under blacklight to isolate leak.
Check supercharger oil supply for leaks also.
Get fixed ASAP, an oil leak on exhaust can cause an oil fire and that would be a big mess.
SPONSORED LINKS
Sunday, May 3rd, 2009 AT 7:27 AM
