Normal for your car should be around 750 rpm. At 1000, your a little high. The possible cause of both high and rough idle could be a vacuum leak. Check all your vacuum hoses for cracks, splits or rotted ends where they attach to the engine intake manifold.
Do you have, or have you had, a check engine light? If yes, you will need to have the ECM scanned to retrieve the stored code from ECM memory and pass them on to us. We can go from there. Please advise.
SPONSORED LINKS
Tuesday, April 7th, 2009 AT 1:06 PM
