2001 Pontiac Grand Prix Replace Spark plugs and wires
2001 PONTIAC GRAND PRIX
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
TONY BONSIGNORE
I need to replace the spark plugs on a 2001 Grand Prix. It has the 3.1L engine. I cannot get to the back three, and I was wondering if there is some simple way to get to them.
Jul 28, 2008 at 7:22 AM
KLSHIEL
  • 163 POSTS
The engine has a "wishbone" connected from the front of the engine to the frame. If you take one or both of the bolts out of this connector you will be able to shift the engine forward enough to get your arm behind the engine, and get the plugs changed. Do not forget to replace the connector as this may cause damage when running the engine.
Jul 28, 2008 at 7:38 AM
