the spark plug wires of my grand prix have an aluminum tube around around the boots. how do i remove this tube and then remove the boot from plug ?
Feb 24, 2008 at 4:26 AM
BRIAN 1
✓Experienced Mechanic
you remove them just like you would the plug wire.they come off with the wire.you can acually pull them off with your hand.pull and twist,they should come off with a little effort.make sure you put the metal tubes back on the new wires because they protect the wire from oil dripping on them or any other fluids.
Feb 24, 2008 at 5:16 AM
BLAKJAK20
MEMBER
1 POST
Because I've pulled twisted pried and all with both hands and still can't get it off?
Feb 24, 2008 at 6:53 AM
