1998 pontiac grand prix GTP
CHRJAY
3.8 supercharged, 120000 miles
checked ignition control module- good
replaced fuel pump and fuel filter
checked fuel pump relay-good
fuel pressure decreases after start up
when car is started, will idle for about 2 seconds, then begin to sputter, then die all together
when engine is off, key turned to ON fuel pressure then comes back and holds steady.
Apr 5, 2007 at 10:54 AM
MCFERRANCE
  • 100 POSTS
Just a note about my experience.
Some ignition modules have separate start and run circuits which will make it start then shut off when the key is released to "run" postion. In my experience with this, the module tested ok even though it was bad.
Apr 6, 2007 at 7:28 AM
CHRJAY
thank for the help. talk to a gm tec he said go git a fuel pump res kit. it use on gtp for pump sec speed. the run about $60. you put the new one on the firewall
Apr 13, 2007 at 5:30 AM
