1997 Pontiac Grand Prix Wont start
CODYDPRICE
  • 1997 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 190,000 MILES
No spark at any of the plugs, no test bulbs run when ignition is turned to run, 1997 pontiac grand prix 3.1 se
Sunday, April 5th, 2009 AT 8:10 PM
. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, April 5th, 2009 AT 8:31 PM
CODYDPRICE
No spark still no test bulbs run snap on scanner will not pull codes says no communication replaced computer. Scanner said same thing. Someone told me if I change the gauge cluster it will correct the problem make any sense?
Monday, April 6th, 2009 AT 5:02 PM
Have you checked the things I've mentioned earlier? If not do it-this can get complicated its not a simple fix
Monday, April 6th, 2009 AT 5:18 PM
Related Engine Not Running Content
