1991 Pontiac Grand Am Third Brake Light Fix
MARK0076
1991 pontiac grand am, 87,000 miles--i bought the car recently and i now need to replace the third brake light bulb, but i can't figure out how to get inside it to change it and the manual does not include details about it. how do i get in there? thank you
Apr 12, 2007 at 9:13 AM
LSUSSEL
  • 252 POSTS
You need to open up the trunk, and its going to be on the lid/ top of the trunk. more then likely your going to need to remove the entirior lining, the lining that makes the trunk look good bascily, to keep it from showing the bare metal, it should pull out by removing those plastic tacks, and then you will see the blub unit and assembly and you should be fine from there, let me know if this helps or not.
Apr 18, 2007 at 3:19 PM
Suggested Repair
Open the trunk and access the third brake light from the trunk lid. Remove the interior trunk lining by pulling out the plastic tacks, then reach the bulb unit and assembly to replace the bulb.
Conversation Summary
The owner of a 1991 Pontiac Grand Am with 87,000 miles needs to replace the third brake light bulb but cannot find how to access it, and the manual does not explain the procedure. The expert says to open the trunk, remove the interior lining held by plastic tacks on the trunk lid, and then access the bulb unit and assembly.
