Rear High Center Brake Light
PONTIAC GRAND AM
BRIAN BARNFIELD
How do you change the bulb in the High Center Rear Brake Light on a 1995 Grand Am? I'm unsure how to dis-engage the plastic mount. Or does it come loose at all?
Help
Thanks
Aug 3, 2006 at 12:08 PM
HEADHUNTER
  • 22 POSTS
Disconnect the negative battery cable. Pull the center high-mount stop lamp cover to disengage the retaining tabs. Unfasten the lamp retaining screws.
Remove the sockets using a suitable prybar to release the retaining tabs.
Detach the bulbs from their sockets.
Using a suitable prybar to release the tabs, remove the lamp lens
Aug 3, 2006 at 2:19 PM
