1995 Pontiac Grand Am Thermostat Location
HAWKI4
where is the thermostat on a 1995 pontiac 3.1, automatic
Aug 10, 2007 at 12:58 PM
CLY
  • 308 POSTS
The thermastat is located on the leftside(driverside)of the intake manifold. If you follow the upper radiator hose to the engine it hooks to the thermastat housing. There are two bolts that hold the housing on..
Hint: when replacing the thermastat remove the top bolt and just loosen the bottom bolt. The thermastat housing is slotted for the bottom bolt so you don't have to remove it all the way...
Cly
Aug 10, 2007 at 9:57 PM
Suggested Repair
Locate the thermostat on the driver's side of the intake manifold by following the upper radiator hose to the housing, which is held by two bolts. When replacing it, remove the top bolt and only loosen the bottom bolt because the housing is slotted.
Conversation Summary
The owner asked where the thermostat is on a 1995 Pontiac Grand Am 3.1 automatic. The expert said it is on the driver's side of the intake manifold where the upper radiator hose connects to the housing, which is held by two bolts. When replacing it, remove the top bolt and loosen the bottom bolt because the housing is slotted.
