04 grand am
2004 ALL OTHER MAKES ALL OTHER MODELS
CSLOAN_1
my grand am has never given me any trouble...until now. My add coolant light came on so I added the coolant. It seems to have a leak, although none of the hoses appear to be damaged.
I want to test the thermostat to see if maybe it is sticking, but I have no idea where the thermostat on an 04 grand am is.
Please could someone help me with this one? If my husband found out I broke the car it would be horrible.
Jul 24, 2006 at 6:04 AM
MIKEYBDMAN
  • 623 POSTS
[quote:a0460029af="csloan_1"]my grand am has never given me any trouble...until now. My add coolant light came on so I added the coolant. It seems to have a leak, although none of the hoses appear to be damaged.
Please could someone help me with this one? If my husband found out I broke the car it would be horrible.[/quote:a0460029af]
If your still under warrenty, take it back to the dealer. If you are loosing coolant, and not seeing a leak, then the leak has to be internal. It can be leaking into your oil, or into the intake and being burnt and out the exhaust.
If the thermostat goes bad, then you will have over heating problems. No overheating problems, and the thermostat is working normally.
Jul 24, 2006 at 8:47 AM
CSLOAN_1
Thank-you. The car is overheating which leads me to beleive the thermostat is sticking. Also the leak is coming from under the reserve which would also indicate a sticking thermostat. I had this problem with my 97 grand am but on that one I knew where the thermostat was. I don't where it is on this one.
Jul 24, 2006 at 10:11 AM
MIKEYBDMAN
  • 623 POSTS
[quote:7911d29105="csloan_1"]Thank-you. The car is overheating which leads me to beleive the thermostat is sticking. Also the leak is coming from under the reserve which would also indicate a sticking thermostat. I had this problem with my 97 grand am but on that one I knew where the thermostat was. I don't where it is on this one.[/quote:7911d29105]
2.2L or 3.4L?
Jul 24, 2006 at 10:13 AM
MIKEYBDMAN
  • 623 POSTS
If a 3.4L it is mounted to the end of the Intake manifold. It says you need to remove the crossover exhaust pipe to gain access to the Thermostat Housing. The houseing looks like a small metal tube that attaches to the upper radiator hose. The thermostat is under the housing i mounted in the intake manifold.
2.2L is probably just as much a pin. If you have an automatic tranny, you have to remove the exhaust manifold. Then remove the thermostat housing to water pump feed pipe. The thermostat is located under the pipe.
Jul 24, 2006 at 10:21 AM
