1999 Pontiac Grand Am Rear Tire Seized
SCOTTEE
I have a 1999 pontiac grand am se 2.4l v6 approx 185 000km. My problem is that my rear passenger tire is seized up. I went to pull away and car wouldn't move. I accelerated and it felt like back of car was dragging....and it was just on the passenger side though. Just wondering what could be the problem....and how to fix it.
thanks
Mar 14, 2007 at 8:59 AM
CHEVY22
  • 1,375 POSTS
do you use the e brake when parking , if so check the cable on the right rear and see if its taught , if it is try pulling a little to see if you can un stick it , and get the wheel off to check the brakes for any failures
jim
Mar 14, 2007 at 9:03 AM
Suggested Repair
If the parking brake is used when parking, check the right rear cable for a taut, stuck condition and try pulling it slightly to free it. Remove the wheel and inspect the rear brakes for failures.
Conversation Summary
The owner of a 1999 Pontiac Grand Am said the rear passenger tire seized, so the car would not move and felt like it was dragging on that side. The expert advised checking whether the right rear parking brake cable is stuck taut, trying to free it, and removing the wheel to inspect the brakes.
