1994 Pontiac Grand Am Broken Wheel Wire
The squeak noise makes me think the brakes are down to the warning sensors.
JAck the front end up, block it so it's stable. Grab the wheel in the 3 and nine position and push and pull to feel for play. Then do the same for the 6 and 12 position. do you feel any play? This is to check for wheel bearing , steering or suspension problems as long as you have it up.
Pull wheels off and look to see how thin the pads are and then at the same time see where the dangling wires are going.
Suggested Repair
Treat the dangling plug as a likely ABS wheel-speed sensor harness. Safely raise and support the front end, check the wheel for play at the 3-and-9 and 6-and-12 positions, then remove the wheel to inspect brake-pad thickness and trace the wire. Repair or replace the broken harness if it is the sensor lead, and address worn pads or loose bearings or suspension before a long trip.
Conversation Summary
The owner of a 1994 Pontiac Grand Am GT reported a broken plug and wire behind the passenger front tire, plus popping and squeaking when turning, and asked whether the car was safe for a long drive. The expert said the wire is likely the ABS wheel-speed sensor harness and asked whether the ABS light was on. The squeak may indicate brake pads worn to the wear sensors. Recommended checks were wheel play for bearings, steering, or suspension problems, plus pad thickness and tracing the dangling wires.
